  • Before you can configure reverse path checking on a VLAN, you must assign a valid IP address to the selected VLAN.
Configure reverse path checking on a VLAN to determine if a packet IP address is verifiable. Use reverse path checking to reduce the problems that are caused by the introduction of malformed or forged (spoofed) IP source addresses into a network. After you enable reverse path checking, the switch performs a reverse path check to determine if the packet IP address is verifiable. If the address is not verifiable, the system discards the packet.
Reverse path checking operates in one of two modes:
  • exist-only mode
  • strict mode
  1. In the navigation pane, expand Configuration > VLAN.
  2. Select VLANs.
  3. Select the Basic tab.
  4. Select the VLAN on which you want to configure reverse path checking.
  5. Select IPv6.
  6. Select the Reverse Path Checking tab.
  7. Select ReversePathCheckEnable to enable reverse path checking.
  8. Select exist-only or strict.
  9. Select Apply.
Reverse Path Checking Field Descriptions
Use the data in the following table to use the Reverse Path Checking tab.
Name
Description
Enables reverse path checking on the selected VLAN.
ReversePathCheckMode
Specifies the mode for reverse path checking. The modes are
  • exist-only—reverse path checking checks whether the incoming packet source IP address exists in the routing table. If reverse path checking finds the source IP entry, the packet is forwarded; otherwise, the packet is discarded.
  • strict—reverse path checking checks whether the incoming packet source IP address exists in routing table. If reverse path checking does not find the source IP entry, then the packet is dropped. Otherwise, reverse path checking further checks if the source IP interface matches the incoming interface of the packet. If they match, then the packet is forwarded. Otherwise, the packet is discarded.
The default is exist-only.
